MUM Europe 2020
kclonline
rb850gx2 speed problem
Fri Jan 16, 2015 2:23 pm
RB850GX2 have problems with the network speed
The network environment: 300 m / 100 m
PCQ use simple queue 6 rules
No PCQ:
Have the PCQ:
Is this normal?
Is there any way to improve..
TrollMan
Re: rb850gx2 speed problem
Fri Jan 16, 2015 4:34 pm
Could you share your config and also a profile screenshot?
kclonline
Fri Jan 16, 2015 4:39 pm
Can, but I don't know which ones to share.
Can you tell me about it?
InoX
Fri Jan 16, 2015 10:09 pm
Your firewall is using too much cpu.
kclonline
Sat Jan 17, 2015 6:56 am
  • /ip firewall mangle
    add action=mark-connection chain=prerouting connection-mark=!heavy_traffic \
    new-connection-mark=all_conn
    add action=mark-connection chain=postrouting connection-mark=!heavy_traffic \
    add action=mark-connection chain=prerouting connection-bytes=500000-0 \
    connection-mark=all_conn connection-rate=200k-100M new-connection-mark=\
    https_traffic port=23,80,443 protocol=tcp
    add action=mark-connection chain=postrouting connection-bytes=500000-0 \
    https_traffic port=23,80,443 protocol=udp
    heavy_traffic port=!23,80,443 protocol=tcp
    heavy_traffic port=!23,80,443 protocol=udp
    add action=mark-packet chain=prerouting connection-mark=https_traffic \
    new-packet-mark=https passthrough=no
    add action=mark-packet chain=postrouting connection-mark=https_traffic \
    add action=mark-packet chain=prerouting connection-mark=heavy_traffic \
    new-packet-mark=heavy passthrough=no
    add action=mark-packet chain=postrouting connection-mark=heavy_traffic \
    add action=mark-packet chain=prerouting connection-mark=all_conn \
    new-packet-mark=other passthrough=no
    add action=mark-packet chain=postrouting connection-mark=all_conn \
I do QOS with these rules.
Then the rules of firewall is the default.
Maybe it's my rule is not good enough?
lambert
Long time Member
Long time Member
Mon Jan 19, 2015 8:06 am
I would start by putting the passthrough=no rules immediately following the rules which create the connections marks they look for. I think you will spend less time comparing traffic for each possible condition before short circuiting out of the loop.
Then, look for the set of rules which see the most traffic in the bytes or packets counters. Make sure the highest traffic conditions are matched earliest in the rule order. That will permit the passthrough=no rules for the highest volume condition to short circuit evaluation of all following rules as quickly as possible saving the most possible CPU time.
TrollMan
Mon Jan 19, 2015 9:43 am
Sort you rules and add pass through no where possible is a great start. Also i would look into the rules too, you have some with byte count, I would guess that this too adds cpu.
kclonline
Thu Feb 05, 2015 3:19 pm
Thanks to the guidance of the two, I will try to optimize rules to the best. :D
Users browsing this forum: biravaian and 31 guests
