MUM Europe 2020
kometchtech
For filtering of log
Mon Feb 02, 2015 8:53 am
Hello, all
Although log such as the following when you add all at once to the address list, etc. Script is output, I wonder Is there a way to suppress it?
/system logging
add action=memory topics=!system,!info
15:49:56 system, info address list entry removed by admin
Best regards.
Routerboard Users Group JP
http://www.rb-ug.jp/
CCR1009-8G-1S-1S+, RB750Gr3, CRS226-24G-2S+, RB850Gx2, RB960PGS, CRS317-1G-16S+,
RB2011UAS, CRS125-24G-1S, RB962UiGS-5HacT2HnT, CRS212-1G-10S-1S+, RB3011UiAS
alexrn
Re: For filtering of log
Mon Feb 29, 2016 1:20 pm
I had the same issue, but not found any solution to filter the logs. But I found the solution that we can use inside the script.
# Disable Logging so each add and remove isn't in the system log, we turn it back on at the end
:log debug "Disabling system Logging";
/system logging disable
.... {your code here} ....
# Enable the Logging
:log debug "Enabling system logging";
/system logging enable
Splash
Mon Feb 29, 2016 2:00 pm
You could try this, but it may hide other system log messages you still want. In a nutshell edit the default 'info' topic and add an additional topic 'system' but in this case, negate it so that it ignores all info-system messages.
Check the number of the logging item, to make sure you are editing the correct one.
/system logging
set 0 action=memory topics=info,!system
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
Users browsing this forum: chilliflakes, fedus, fruitjuice, gfucka, karlisi and 30 guests
