Tue Jul 28, 2015 10:16 pm
I'm having the issue of a circuit failing, and the connection goes idle.
Doesn't matter how long I leave it, until I disable and re-enable the PPPoE interface, it stays idle.
If I change the interfaces from two, using Ether8 and Ether9, if I add Ether10, Apply, and then connect a third modem, it connects using the third, and everything works as it should.
If I then disconnect the new modem, either disconnect the Ethernet cable so Ether10 goes offline, or just the telephone wire from the modem, the connection just sits idle until I disable-enable the connection again.
Has been bugging me for a while now, I don't know why it does this, or where to look.
Ideally I'd love for a circuit to go down, and no noticeable impact to my internet connection. Maybe a second or two outage while it removes the circuit from the group, until it comes back online.
If a circuit goes down for any reason, the connection stays idle until that circuit comes back on, then it goes back to working.
If it can add one without issue, should be able to remove it after?
