mbfound
Need some PtMP help
Fri May 22, 2015 6:11 pm
Hi
I'm trying to set up a PtMP local network that will share internet between 3 houses.
I've set up the main groove as a WISP AP with nv2 and 2 Grooves (Soon to be 2 SXTs) as CPE.
If that setup is incorrect PLEASE correct me.
The way I have it currently works perfectly fine, both CPEs get IP, devices connected to it get an IP, internet works until I try to enable security:
On Quickset I set the router to CPE, find the WISP, select it and connect. It asks for the password I enter on the WISP but keeps getting stuck in "searching for network" with the connect button now turned to disconnect.
On the WISP AP's Quick Set, I tick the security box and type in 00000000 as the pass, it accepts and goes on as normal.
So I basically just need confirmation if the settings for the network are correct and why the NV2 security wont work.
(2Ghz Only N)
pukkita
Trainer
Trainer
Re: Need some PtMP help
Sat May 23, 2015 3:54 pm
what is the wireless mode set in the AP?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
mbfound
Mon May 25, 2015 11:35 am
Hi pukkita
pukkita
Trainer
Trainer
Mon May 25, 2015 11:43 am
nv2 mode uses its own security, set nv2 tab security field on CPEs to the same on AP.
mbfound
Mon May 25, 2015 11:55 am
Thanks for the quick reply. I set the passsword to 00000000 but it just keeps saying "searching for network"
Main AP
CPE
(The cpe has an IP because its connected via ethernet - doesn't affect the connection without security)
pukkita
Trainer
Trainer
Mon May 25, 2015 12:05 pm
I think you should try using winbox alone, setting the nv2 password manually on the CPEs, the password in quick set may refer to wpa; go to Wireless > Interfaces > wlan1 nv2 tab on the CPE.
mbfound
Mon May 25, 2015 12:22 pm
100% correct, it worked immediately.
Users browsing this forum: Baidu [Spider], ifoel and 47 guests
