kellogs
Adding another eBGP router and upgrade to OSPF for IGP
Mon Sep 21, 2015 6:41 am
Dear Mikrotik Experts,
I am in the process of adding another EBGP routers with 2 upstream providers and would like to establish IBGP to the existing EBGP router via vlan 101 on this diagram.
Is it better for me to enable client-to-client-reflection on both EBGP router?
Beneath the EBGP routers we have 7 distribution routers which has total 89 static routes to the current EBGP router.
I would like to eliminate the static routing and has each distribution router connected via OSPF to both eBGP routers for redundancy via vlan 102 and all of them are on /25 subnet.
Could you kindly provide your comment on this setup please?
Thanks!
wulfgard
Re: Adding another eBGP router and upgrade to OSPF for IGP
Tue Sep 22, 2015 3:05 am
Hello
just do ibgp and push default route through ospf
1) add loopback interface with /32 ip on each router
2) setup ospf between routers and advertise loopback
3) setup bgp between both loopback address using your AS number
4) for bgp setup use next-hop=self and source address=loopback
5) you are done
i would advise to ask your upstream to send you a default route in bgp
so you can activate "redistribute default route if exist" in ospf
cheers
Thierry
System and Network Engineer
Mikrotik Trainer - MTCNA MTCRE
Official French Mikrotik Distributor
wulfgard
Tue Sep 22, 2015 3:09 am
Oups double click
Users browsing this forum: No registered users and 2 guests
