conchalnet
Issues with OSPF
Sun Nov 01, 2015 1:34 pm
I've two CCR1036 using the RouterOS 6.32.3 with last firmware. They are connected by optic fiber and running OSPF.
Sometimes I've problems on the OSPF and it stops to work for a short period.
The RouterOS logs these informations:
01:07:52 route,ospf,info Database Description packet has init bit set in middle of an exchange
01:07:52 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Full to 2-Way
01:08:43 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Full to Init
01:08:49 route,ospf,info Database Description packet has init bit set in middle of an exchange
01:08:49 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:09:29 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:09:47 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:09:59 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from ExStart to Down
01:10:00 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from ExStart to Down
01:10:20 route,ospf,info Discarding packet: no neighbor with this source address
01:10:20 route,ospf,info RouterId=10.99.99.12
01:10:20 route,ospf,info source=10.100.101.26
01:10:20 route,ospf,info source=10.100.100.26
01:11:02 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:11:07 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:11:44 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:11:48 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:11:57 route,ospf,info Database Description packet has init bit set in middle of an exchange
01:11:57 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:12:54 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
OSPF configuration on Router 1:
/ip address> print
#   ADDRESS            NETWORK         INTERFACE
0   10.100.101.25/30    10.100.101.0    ether11
1   10.100.100.25/30    10.100.100.0    sfp3
2   10.99.99.2/32       10.99.99.2      lobridge
/routing ospf instance> print
Flags: X - disabled, * - default
 0  * name="default" router-id=10.99.99.2 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no
      metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=auto metric-other-ospf=auto in-filter=ospf-in out-filter=ospf-out
/routing ospf interface> print
Flags: X - disabled, I - inactive, D - dynamic, P - passive
 #    INTERFACE        COST PRIORITY NETWORK-TYPE   AUTHENTICATION AUTHENTICATION-KEY
 0    sfp3        10        1 point-to-point none
 1    ether11        30        1 point-to-point none
/routing ospf network> print
 #   NETWORK            AREA
 0   10.100.100.24/30   backbone
 1   10.100.101.24/30   backbone
 2   10.99.99.2/32         backbone
OSPF configuration on Router 2:
/ip address> print
0   10.100.101.26/30    10.100.101.0    sfp1
1   10.100.100.26/30    10.100.100.0    sfp2
2   10.99.99.12/32       10.99.99.12   lobridge
 0  * name="default" router-id=10.99.99.12 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no
 0    sfp1        30        1 point-to-point none
 1    sfp2        10        1 point-to-point none
 #   NETWORK            AREA
 2   10.99.99.12/32		backbone
Can someone help me?
scampbell
Trainer
Trainer
Re: Issues with OSPF
Sun Nov 01, 2015 11:59 pm
I would try setting the Network-Type =Broadcast on all interfaces rather than Point to Point.
With Network-Type=Point to Point no router is elected as designated router under OSPF. This is good on a wireless segment of an OSPF network but perhaps not so good in your situation ?
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
IPANetEngineer
Trainer
Trainer
Mon Nov 02, 2015 5:22 pm
If it's a production network, I would be running the latest stable bugfix which is 6.30.4 and see if the issue persists.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
conchalnet
Tue Nov 03, 2015 1:44 am
Thanks for the reply!
Yes the router are in production and I'm running 6.32.3 that is the last stable version of RouterOS, do you think that the 6.30.4 is a best choice for OSPF?
IPANetEngineer
Trainer
Trainer
Tue Nov 03, 2015 2:42 am
Latest stable is a bit misleading as the latest bugfix version is generally considered the most stable all around code for production networks unless the latest stable current release contains features that are needed.
we have recommended 6.30.4 bugfix to all of our clients and have multiple networks running OSPF/BGP/MPLS on that version with no issues.
Here is an article we did on the new MikroTik code development
http://www.stubarea51.net/2015/08/04/mi ... ent-cycle/
Users browsing this forum: No registered users and 6 guests
