src386
VRRP failover isn't working
Tue Dec 08, 2015 6:46 pm
Hi everyone,
I'm using two RouterOS 6.33.2 x86 VM in Virtualbox.
Router1 is 172.16.42.10 on ether3, Router2 is 172.16.42.20 on ether3. Both are able to ping.
I added vrrp1 interface on both routers, same vrid (44) on ether3. My virtual IP is up on Routeur1 (highest priority), but when I disable ether3 on Router1, the virtual IP goes down, instead of "moving" to Router2.
Here is the configuration (without disabling ether3 on Router1) :
Routeur 1:
[admin@mikrotik1] > /interface vrrp print detail
Flags: X - disabled, I - invalid, R - running, M - master, B - backup
 0 I   name="vrrp1" mtu=1500 mac-address=00:00:5E:00:01:2C arp=enabled
       interface=ether3 vrid=44 priority=101 interval=1s preemption-mode=yes
       authentication=none password="" on-backup="" on-master="" version=3
       v3-protocol=ipv4
[admin@mikrotik1] > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 3   172.16.42.10/24    172.16.42.0     ether3
 4 I 172.16.42.254/32   172.16.42.254   vrrp1
Routeur 2:
[admin@mikrotik2] > /interface vrrp print detail
       interface=ether3 vrid=44 priority=100 interval=1s preemption-mode=yes
       v3-protocol=ipv4
[admin@mikrotik2] > /ip address print
 3   172.16.42.20/24    172.16.42.0     ether3
Everything seems okay, where is the problem ?
Thanks.
src386
Re: VRRP failover isn't working
Thu Dec 10, 2015 12:11 pm
This problem seems to be related to Mikrotik x86 + Virtualbox.
Mikrotik x86 + Physical PC works.
Users browsing this forum: Maxnnet and 43 guests
