stafross
vrrp Virtual IP address not respondig
Thu Feb 04, 2016 3:04 pm
I have 2 instances of ROS v6.34.1 on CHR running on ESXi.
I have setup vrrp on both and fail-over works as expected
If I try to ping the virtual IP from the backup router it does not respond, neither can I connect to the virtual IP.
Anyone got any idea what can be wrong?
stafross
Re: vrrp Virtual IP address not respondig
Fri Feb 12, 2016 2:47 pm
Hi
I have now tested this on ESXi and VirtualBox with a x86 and CHR (x86_64) image and in both these cases the virtual IP cant be pinged or connected to.
Below is the config script that I use on a clean install.
R1
/interface vrrp
add interface=ether2 name=vrrp1 priority=225
add interface=ether2 name=vrrp2 vrid=2
add address=192.168.100.3/24 interface=ether2 network=192.168.100.0
add address=192.168.100.1 interface=vrrp1 network=192.168.100.1
add address=192.168.100.2 interface=vrrp2 network=192.168.100.2
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/system identity
set name=LB1
R2
/interface vrrp
add interface=ether2 name=vrrp2 vrid=2 priority=225
add address=192.168.100.4/24 interface=ether2 network=192.168.100.0
/ip dhcp-client
/system identity
set name=LB2
I need to get this working else I need to look at using another system.
ZeroByte
Fri Feb 12, 2016 5:53 pm
Why two vrrp interfaces?
stafross
Mon Feb 15, 2016 9:05 am
This is for load balancing with fail-over.
telepro
Fri Sep 11, 2020 10:51 pm
Was a work-around found to get the virtual IP address to respond to a ping request?
Users browsing this forum: No registered users and 61 guests
