veso266
UDPXY alternative for mikrotik
Sun Oct 02, 2016 8:29 pm
Hi I would like to know is there any alternative for udpxy in RouterOS (or will udpxy support be added)
as I am now running OpenWRT MetaRouter just for udpxy and it is a wate of resources as CPU goes up to 100% when I start to play a stream on my pc (it can only convert SD Channels from multicast to unicast (HD Channels just freeze))
I am running this on RB2011UiAS-2HnD-IN so is there a better way of converting from multiacst to unicast so you can send multicast stream over wifi or VPN?
Thanks for Anwsering and Best Regards
imac
Re: UDPXY alternative for mikrotik
Fri Feb 17, 2017 4:33 pm
Hi!
Any updates on this issue ? Do you plan to make UDPXY ?
Watching multicast IPTV is awful !
HaQs
Fri Jun 16, 2017 5:32 pm
+1 for UDPXY or any alternative
tomasvilda
Wed Dec 06, 2017 12:25 pm
+1 for updxy or something similar.
Ordered mikrotik router, found out that it doesn't support udpxy, cancelled order. Waiting for support.
Beone
Tue Apr 03, 2018 2:23 pm
+1
this would resolve some issues with Multicast for STBs compatible with udpxy
futurion
Sat Sep 08, 2018 11:39 pm
I'm bringing this thread to life as I'm also wondering if there's any kind of solution to this matter available? I'd be also more than happy to have an option to convert multicast to unicast directly with mikrotik router.
I guess udpxy isn't and won't be available. Do we have some kind of alternative?
Etz
Sun Sep 23, 2018 7:10 pm
Not that I'm aware of, hopefully we will get udpxy eventually...
mccreigh
Wed Oct 03, 2018 5:23 pm
Please, please, please, a udpxy module to augment the multicast module?? Multicast TV is effectively useless over WiFi links because WiFi shifts to its slowest (and most noise-immune) speed for broadcast-like packets. Besides that, experience indicates that Windows 10 can be fragile in the multicast area. And LAN switches (including my TP-Link SG-3424's) don't always do IGMP snooping correctly, especially for edge cases.
Yes, it's possible to put a wired Linux box on the LAN and do upd multicast - to - http unicast proxying there, but it seems exactly the sort of thing a router could do well and inexpensively. If MikrotTik would implement udpxy, IPTV ISP's (like mine, init7.net) might start preferring MikroTik routers for their clients, don't you think?
veso266
Fri Sep 20, 2019 4:16 pm
just so its no forgotten
udpxy or something similar would be great
Users browsing this forum: No registered users and 6 guests
