MUM Europe 2020
sabakinaz
Multicast VLAN over a EOIP/IPSec tunnel
Sat Dec 17, 2016 10:28 am
I am trying to forward an IPTV VLAN over the encrypted tunnel. The main local Internet facing router is an Ubiquiti ER-X because of the hardware NAT. On the local LAN I have a MIkrotik RB850Gx2 acting as a VPN / IPSec endpoint to all my connections. So basically to have the remote HAP LIte to be able to transfer VLAN over an encrypted tunnel I have to setup the tunnel in 3 stages:
1) Setup a GRE tunnel between remote HAP Lite and RB850. At this stage ER-X forwards pure GRE to RB850. I cannot do an EOIP tunnel because ER-X won't forward GRE packets if I setup EOIP interfaces on MIkrotiks on both sides somehow (anyone knows how to adjust ER-X for this?).
2) Setup an IPSec over the GRE tunnel between the GRE tunnel interfaces;
3) Setup an EOIP tunnel between the GRE tunnel interfaces.
At this stage the traffic flows fine, I can ping the endpoint in and out and vice versa. Now the question is (I am not sure if this is even possible, that's why this new thread here):
If I create a bridge with the IPTV VLAN alongside with a new VLAN created on top of the EOIP endpoint as the bridge ports within RB850 and afterwards I create a VLAN interface on the remote HAP Lite, everything works as expected: DHCP works, traffic flows, IPTV STB works fine. But because I encrypt the whole VLAN this means that if a local STB is turned on the multicast traffic is transmitted over the IPSEc tunnel as well. I have measured the IPSec performance with the Bandwidth tool over to HAP Lite. Considering the overhead of the GRE / EOIP tunnels the max throughput I could get was 20Mbit/s. The problem is if more STBs gets tuned in the remote HAP Lite will not be able to encrypt / decrypt it's own traffic because all the other multicast traffic would still be there. Is there a way to avoid this situation? I would like the remote STB to only see the traffic destined for it only. Maybe some bridge filtering or multicast routing would do this? I consider myself lucky to go this far, knowing I am not a networking guy at all, but this is where I stop because of the lack of ideas. I am grateful for any hints.
Thanks,
Darius.
sabakinaz
Re: Multicast VLAN over a EOIP/IPSec tunnel
Tue Jan 03, 2017 4:43 pm
Anyone please?
tsvgos
Tue Jan 03, 2017 10:32 pm
You need IGMP snooping to limit the traffic passing through the bridge. Currently, Mikrotik does not support IGMP snooping.
To implement multicast routing you should at the sources ( the routing interface facing the multicast must be in the same logical segment as the source).
sabakinaz
Sat Jan 07, 2017 12:28 pm
Thanks for the response tsvgos.
Is there any way to apply some filter to the bridges or something similar? I don't have the access to the multicast source servers unfortunately.
Thanks.
pe1chl
Sat Jan 07, 2017 12:49 pm
Yes, you can filter traffic in bridges. You could have studied that in the manual.
sabakinaz
Sat Jan 07, 2017 1:39 pm
What exactly should I target at the filter? MAC addresses / IPs, something else? There is a plethora of options in the bridge filter, I got totally lost in those.
Thanks!
Darius.
nivis
Tue Jan 10, 2017 11:07 pm
Hi!
Start by saying that I have not the answer for you but I'm in the same situation as you. I'm sending multicast IPTV over an EOIP-tunnel but I use an SSTP tunnel as a 'carrier' for the EOIP. The problem you mention that the multicast streams for several STB are sent over the 'bridge' ie EOIP-tunnel and caps the mikrotiks is exactly what I see here. I was searching for IGMP-snooping when I found your thread and maybe we could work this filtering question out. I'm not in any way a RouterOS guru so bare with me.
I have done several tests and have found that the maximum bandwidth I can get between my routers are ~ 27 Mbit over the EOIP-tunnel when I use the bw-test that's found in the RouterOS. This is more than enough for both SD and HD channels as they in my environment consumes 5.4 resp 13 Mbits. I can watch SD without problem but when I switch to an HD channel the video starts to stutter and sound is cracking. This is very strange but I have found out that when I switch channel, it take some time before the 'old' stream stops and I think that this has to do with the underlaying multicast behaviour ie the source has not stopped the stream because it is unaware that there are no listeners. ( IGMP snooping anyone? ) :)
krzysztof
Sat Jan 21, 2017 1:14 pm
IGMP and PIM.
Normis said that this will not improve.
IGMP and PIM will not be improved and supported in the coming years
Users browsing this forum: No registered users and 8 guests
