lcm
Trainer
Trainer
BFD Open port on default conf
Sat Dec 24, 2016 5:13 pm
Hi Guys,
I have a client that are expericneing errors on log like this:
discarding BFD paclet: too short
source "many public ip"
On my home router (rb951-2hnd), basic conf, no dynamic routing protocols, the BDF UDP 3784 port is open:
Starting Nmap 6.40 ( http://nmap.org ) at 2016-12-24 11:39 BRT
Nmap scan report for 192.168.0.1
Host is up (0.00085s latency).
PORT STATE SERVICE
3784/udp open|filtered bfd-control
MAC Address: D4:CA:6D:BE:48:B6 (Routerboard.com)
Nmap done: 1 IP address (1 host up) scanned in 0.50 seconds
Is it the expected behavior? BFD is enabled by default on RouterOS?
Is there any known Atack on BFD port?
Thanks for your time.
Greets from Brazil.
Luiz Claudio Martins Maia
zipvault
Re: BFD Open port on default conf
Sun Dec 25, 2016 11:16 am
I noticed one of my routers connects to mikrotik server on inital hard reset thought this was slightly strange
ZipVault
lcm
Trainer
Trainer
Mon Dec 26, 2016 4:52 pm
Thanks for your answer zipvault, but i think its a different subject.
Anyone else?
Greets from Brazil.
mrz
Tue Dec 27, 2016 1:04 pm
BFD listens to that port by default when routing package is enabled.
chubbs596
Fri Sep 04, 2020 1:20 pm
Hi ,
I recently started using BFD to allow quicker failover in case a BGP peer fails, is there any need to protect the router with a firewall ? We try and not make use of a firewall on our edge to allow for maximum forwarding capacity, we protect the routers using by restricting ip service to local network only,
mrz
Fri Sep 04, 2020 1:44 pm
You can set raw rules to accept packets from known destinations.
Users browsing this forum: No registered users and 27 guests
