Kirikov
Branches not ping each other
Thu Mar 02, 2017 10:19 am
There are three branches and the central office:
Branches normally Ping headquarters and not ping each other
RIP branch:
DeamonMV
Re: Branches not ping each other
Thu Mar 02, 2017 4:04 pm
What router associated with IP 169.254.1.153?
What IP have HQ router?
Kirikov
Thu Mar 02, 2017 4:11 pm
address of the head office of the tunnel
Kirikov
Thu Mar 02, 2017 4:13 pm
GRE tunnel between the central office and a branch office
IPANetEngineer
Trainer
Trainer
Thu Mar 02, 2017 8:10 pm
You are most likely hitting the split horizon limitation of RIP. I don't believe that MikroTik has the capability to disable split horizon like you can in Cisco.
The options you can consider are:
1. Move to OSPF - it is a far better and faster routing protocol than RIP
2. Enable a full mesh of tunnels between sites
3. Add static routes to make up for the routes being stopped by split horizon.
I would strongly recommend option 1 to make routing easier.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Kirikov
Fri Mar 03, 2017 8:58 am
Thank you, I will try
Users browsing this forum: No registered users and 7 guests
