If I'm using OSPF with loopback interface and I want to set an IP address to the loopback interface which one should it be? /30 or /32?
Hi,and set interface to p2p passive.
Include ip in the networks tab
verify ospf interface up.
Done.
The network type won't matter as it is passive. You may choose to hard code the interface to passive to ensure that it doesn't try to form a neighbor relationship on it ever just to be safe if you wish though.Hi,and set interface to p2p passive.
Done.
for using loopback in ospf network should i use P2p network type ? I just add loopbackip to ospf network as backbone and its come automatically to ospf interface as dnymic passive.
thanks
Idlemind is right. And I allways think of security/stability in layers. if something can be configured more strict it should, as it tend not to break if someone makes a misstake later on.The network type won't matter as it is passive. You may choose to hard code the interface to passive to ensure that it doesn't try to form a neighbour relationship on it ever just to be safe if you wish though.Hi,and set interface to p2p passive.
Done.
thanks
