ajmacias
PPPoE + OSPF = Discarding packet: locally originated
Fri Nov 17, 2017 12:33 pm
Hi!
Since upgrade to 6.39.3, lots of messages of this kind in logs.
Nothings have changed in network topology, only upgraded routers to 6.39.3 (bugfix only).
The message appears every time a user connects or disconnects from PPPoE.
Each PPPoE server is in his own interface: i haven't bridges.
I've 3 routers (2xRB3011 and 1xRB2011) with this problem.
It's a mikrotik bug or can be other problem ??
Thanks!
11:06:47 pppoe,info PPPoE connection established from XX:XX:XX:C6:E1:B1
11:06:47 pppoe,ppp,info,account some.pppoe.user logged in, AA.BB.CC.4
11:06:47 pppoe,ppp,info <pppoe-some.pppoe.user>: authenticated
11:06:47 pppoe,ppp,info <pppoe-some.pppoe.user>: connected
11:12:10 route,ospf,error Discarding packet: locally originated
11:12:10 route,ospf,error     src address=10.ZZ.0.TY
11:12:10 route,ospf,error     src address=10.ZZ.0.TT
11:13:28 route,ospf,error Discarding packet: locally originated
11:13:28 route,ospf,error     src address=10.ZZ.0.TA
11:13:28 route,ospf,error     src address=10.ZZ.0.TP
mrz
Re: PPPoE + OSPF = Discarding packet: locally originated
Fri Nov 17, 2017 12:34 pm
There is a loop in your network or two OSPF neighbors with the same ID.
ajmacias
Fri Nov 17, 2017 12:42 pm
Nothings have changed in network topology:
no new router, no new links, no new switches...
Only upgraded routers.
Anyway, the error does not spread to more nodes, only to those 3.
I will check the configuration again, and / or install version 6.38
ntblade
Re: PPPoE + OSPF = Discarding packet: locally originated  [SOLVED]
Mon Nov 27, 2017 11:03 pm
We've found the cause of the OSPF errors (ms-configured switch) but the PPPoE drop outs still remain
marklodge
Tue Jul 14, 2020 4:52 am
i had the exact same issue
please tell me what was mis configured
Users browsing this forum: No registered users and 22 guests
