nichky
Long time Member
Long time Member
TE- Failover Testing
Thu Mar 08, 2018 10:42 am
Using this example:
https://wiki.mikrotik.com/wiki/Manual:Simple_TE
About Failover Testing, MikroTik already says:
"Note: Switching from primary to secondary path may not be as fast as expected. It depends on OSPF dead timeouts, routing table updates and timeout settings in TE tunnel configuration."
Just i need your experiance how long does it take? in my case it takes 2 min :)
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
Vooray
Re: TE- Failover Testing
Thu Mar 08, 2018 5:32 pm
2 mins is realy alot.
Can you add bfd to your setup and share results?
mrz
Thu Mar 08, 2018 5:42 pm
By enabling BFD or reducing OSPF dead interval
and
setting lower TE reoptimize interval and primary-retry-interval
nichky
Long time Member
Long time Member
Thu Mar 08, 2018 9:41 pm
and
@mzar
I've done that,normally how long do i need to expect,approximal?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
Users browsing this forum: No registered users and 7 guests
