marklodge
Static routing instead of OSPF
Wed Apr 25, 2018 10:05 pm
I have a ring of 7 routers, running MPLS and VPLS with OSPF routing.
I am picking up high latency issues between two points, so I suspect looping somewhere along the line.
I am thinking about cancelling OSPF routing and just creating static routes, what are your thoughts?
IPANetEngineer
Trainer
Trainer
Re: Static routing instead of OSPF
Thu Apr 26, 2018 3:47 am
OSPF is incredibly resilient to routing loops unless you're redistributing prefixes and have a config or design issue. It is the backbone of almost every network we work on for MikroTik - whether by itself or as the transport for iBGP and MPLS/LDP.
It sounds like you may have a config or other issue causing looping or otherwise injecting latency. Is the ring based on fiber, copper or RF?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Anumrak
Thu Apr 26, 2018 3:47 pm
Simple OSPF is better.
Users browsing this forum: No registered users and 9 guests
