n4p
Block traffic between eoip tunnels
Wed May 02, 2018 8:35 pm
I wanna ask if it would be possible to block traffic between multiple eoip tunnels connected to the same bridge interface.
They should only can talk to one pysical port connected to the bridge.
Thanks!
Sob
Re: Block traffic between eoip tunnels
Wed May 02, 2018 11:50 pm
Bridge ports have "horizon" option which should do what you want:
Set the same value for group of ports, to prevent them from sending data to ports with the same horizon value.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
sri2007
Fri May 04, 2018 4:08 pm
Hi, there is also a fixture called filter under bridge that can be used for this. Please check at this link to find more info: https://wiki.mikrotik.com/wiki/Manual:I ... e_Firewall
MikroTik Support and Consultancy - Español / English +593 93 924 1262
https://www.safenet.ec/consultoria.html/ support@safenet.ec
Users browsing this forum: No registered users and 20 guests
