Itmonkee
Configuring a VRF on Single MT Router
Thu Aug 23, 2018 9:27 am
All,
I'm wondering if it would be possible to configure a VRF(s) on a single MT Router? At the moment, I'm using separate VLAN's at the moment to segregate the different networks. However, I'm wanting to try and take a different approach with segregating this traffic and would like to use VRF's for this. I have used VRF's in the Cisco world and thought it would be a good idea to try and use VRF's on my favorite MT router!
At the moment, the issue I seem to be having is how do I get the VRF INTERNET of which is on VLAN 100 to NAT out to the Internet? I have searched Google, Youtube, and MT Forum but I have not had much success trying to set this up on a single MT Router. Is this even possible or am I going about this in a inefficient way? Any assistance with this issue is greatly appreciated.
My configuration is as follows:
add distance=1 gateway=103.125.127.33 routing-mark=INTERNET
add action=masquerade chain=srcnat log=yes log-prefix="internet ###" routing-mark=INTERNET routing-table=INTERNET
/ip route vrf
add interfaces="VLAN 100 - LAN" route-distinguisher=1:100 routing-mark=INTERNET
add address=192.168.100.1/24 comment="Internet LAN" interface="VLAN 100 - LAN" network=192.168.100.0
add address=104.219.115.38/27 interface=WAN network=103.125.127.45
/interface vlan
add comment=Internet LAN interface=ether2 name="VLAN 100 - LAN" vlan-id=100
WAN Info:
103.125.127.32/27
103.125.127.33 - Default GW (ISP)
103.125.127.45 - WAN Interface
LAN Info:
192.168.100.0/24
192.168.100.1 - GW
*** Public WAN IP Info has been replaced with dummy PUBLIC IP for security purposes ***
Thanks | Regards,
John
IPANetEngineer
Trainer
Trainer
Re: Configuring a VRF on Single MT Router
Fri Aug 24, 2018 8:09 pm
You're close but you need to add the WAN interface to the VRF interfaces as well.
Also remove the routing-table=INTERNET on the NAT rule and just match on routing mark
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Itmonkee
Sat Aug 25, 2018 1:43 am
Thanks, I'm going to try again either tonight or tomorrow and Ill let you know how it goes. Thanks for the nudge in the right direction, very much appreciated.
Itmonkee
Sat Aug 25, 2018 2:23 am
Ok, I was able to find a few minutes of downtime to test this out... so the following code has been corrected as advised earlier. When performing this test, I was not able to get out to the Internet. It took me a few minutes to realize that there was an up/down arrow to add additional interfaces to the vrf INTERNET. Also, the routing-table has been removed from the NAT statement.
Any idea what else I might be missing?
/ip route vrf
add interfaces="VLAN 002 - LAN,WAN" route-distinguisher=1:2 routing-mark=INTERNET
Users browsing this forum: No registered users and 6 guests
