MUM Europe 2020
Hun2
Routing bug
Sat Sep 15, 2018 10:28 am
On version 6.39-6.40.9, routing hangs after rebooting. I have to go from the connected networks and disable - enable all IP addresses so that the routing starts working. Also helps restart interfaces, bridges, GRE interfaces and so on.
The router uses BGP OSPF MPLS VPLS protocols. This routing bug becomes a big problem. Originally installed CCR1009, it was replaced by CCR1036, but no improvements were noticed. Tried to disable OSPF and reboot the router. it is often run without problems, but sometimes routing hangs again. Also there was a ticket to the support service.
I'm looking forward to the update with the fixes.
IPANetEngineer
Trainer
Trainer
Re: Routing bug
Sat Sep 15, 2018 2:21 pm
There are a lot of stable MIkroTik networks with BGP, OSPF, MPLS/VPLS on the CCR series.
Can you post your config? Do you have a network diagram?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Users browsing this forum: ceylan and 3 guests
