freshtechs
Setup IPv6 L2TP Server to provide IPv6 connectivity on iOS L2TP client
Mon Sep 17, 2018 8:44 am
My IPv4 setup is working fine clients connects to router and are all traffic is routed to it. I want to accomplish the same using IPv6 so client can reach IPv6 addresses from my router. Is it possible and how?
mdyring
Re: Setup IPv6 L2TP Server to provide IPv6 connectivity on iOS L2TP client
Thu Dec 20, 2018 11:45 am
Did you manage to sort this out? Facing similar issue with L2TP connection to Mac OSX Mojave where IPv6 doesn't work.
freshtechs
Fri Dec 21, 2018 7:33 pm
No.
mducharme
Trainer
Trainer
Fri Dec 21, 2018 8:13 pm
This doesn't work on MacOS because for some reason MacOS doesn't do SLAAC on ppp interfaces. People have created hack-ish workarounds like a script that does a packet capture to listen to for IPv6 router advertisements and then use that to set the IPv6 address, but that kinda workaround doesn't really scale. I haven't yet found an option that allows SLAAC to work properly on ppp interfaces.
Users browsing this forum: dioeyandika and 31 guests
