Sourav
Real IP Static Route is Not Active in ccr1009-7g-1c-1s+
Tue Dec 18, 2018 3:38 pm
Real IP Static Route is Not Active in ccr1009-7g-1c-1s+ . See the attached image, the red mark not showing active. it is doing a great problem for me. how it will be solved?
TheCiscoGuy
Re: Real IP Static Route is Not Active in ccr1009-7g-1c-1s+
Sat Jan 05, 2019 7:35 am
Does the gateway have a valid arp entry? Also, show the routing table for more info
Network Solutions Engineer and Trainer
Cisco | Juniper | Mikrotik | Ubiquiti
klasaradnicka
Sat Jan 05, 2019 1:50 pm
Are you able to ping gateway ?
Can you post routing table if there is already a route to the destination ?
I had a similar issue on RB 2011 ILN I did a reboot and everything worked fine.
Users browsing this forum: stefki and 16 guests
