kokaKorina
OSPF load balancing
Tue Jan 08, 2019 9:23 pm
Hello everyone
we are moving our wisp from static to ospf and we also want load balancing but I just started working for this company(I had cisco background) there are alot of confusions for me, first is we have two ips on one interface one public and one private,all our customers are on public ip we are not using any NAT at all.In our ring topology if use ospf is it gonna do load balancing too or we have to do it someother way I had looked on google and the only thing I found is magling or marking the packets but we have so many towers is there anyotherway .I am going to attach the topology(ip addresses are just for example) to show what we are looking for.
all replies are appreciated
Ape
Re: OSPF load balancing
Wed Jan 09, 2019 2:09 pm
it's totally possible with MikroTik and OSPF.
Have a look at this great talk:
Video: https://www.youtube.com/watch?v=dFZz2z6RdQY
Presentation: https://mum.mikrotik.com/presentations/ ... 062656.pdf
Regards,
Ape
kokaKorina
Wed Jan 09, 2019 6:29 pm
Hi Ape,
I also have pppoe server running on each routers interfaces except the ether 1 is it gonna effect that pppoe and do i have to add those pppoe(public ips) to the networks for ospf too?
thanks
Anumrak
Forum Veteran
Forum Veteran
Thu Jan 10, 2019 11:59 am
Hi Ape,
thanks
It depends entirely on your architectural solution. I would not drive client services through ospf. Use mpls + mp/bgp.
kokaKorina
Thu Jan 10, 2019 4:25 pm
Thanks anumark
but I have my clients on pppoe and the interfaces on which they are connected is acting as pppoe server for them and they all are on public ip addresses so if I put all those ip addresses on the ospf network too will it work?I am attaching a topology diagram for that .I would appreciate your reply.
Ape
Fri Jan 11, 2019 4:25 pm
Hi
I second this. Use MPLS/VPLS and centralize your PPPoE dialins to one server.
MPLS should be the transport layer for your customer's traffic.
It would be possible to just use the public IP adresses in OSPF, but this setup lacks flexibility for future expansion.
Regards,
Ape
kokaKorina
Mon Jan 14, 2019 4:21 pm
Hi Ape,
I know the problem with this architecture but the thing for just right now i need to setup ospf and i am trying to put iBGP over ospf but the problem I am having is just pppoe and I do not want to move them to centralized location So if i just configure ospf and add pppoe addresses to network for ospf too is it not gonna work?
bbs2web
Mon Jan 14, 2019 9:06 pm
We exclusively use OSPF to distribute router's loopback IPs and necessary point to point or broadcast IPs to reach the loopbacks. All customer, peer or IXP routes are distributed using iBGP route reflectors.
I've detailed the structure in another post, which you can reference here:
viewtopic.php?f=14&t=42268&p=688104#p688104
PS: MPLS forwarding only selects one of the OSPF ECMP paths though, you could leave off LDP and benefit from load sharing or leave as is to transport MPLS frames through a simple OSPF core.
kokaKorina
Wed Jan 16, 2019 4:54 pm
Thanks everyone
Users browsing this forum: Bing [Bot] and 5 guests
