kokaKorina
pppoe with ospf
Wed Jan 09, 2019 6:01 pm
Hello everyone
We are migrating from static routing to ospf and I was just wondering if we are using pppoe for every client is it gonna work with ospf too?
TheCiscoGuy
Re: pppoe with ospf
Mon Jan 14, 2019 10:53 am
PPPoE is a layer 2 protocol, so long as your OSPF instance is configured properly and your BNG/RAS/Concentrator can route to the OSPF infrastructure (and vice versa) then yes.
Network Solutions Engineer and Trainer
Cisco | Juniper | Mikrotik | Ubiquiti
Anumrak
Re: pppoe with ospf
Mon Jan 14, 2019 12:13 pm
You shouldn't route your customers services via ospf. Use iBGP.
TheCiscoGuy
Re: pppoe with ospf  [SOLVED]
Mon Jan 14, 2019 6:31 pm
Since he is currently using static routes, he is not pulling the entire routing table and will not likely overrun the prefix limit with ospf. The question at hand was functional and without further information you can not make the statement that one routing protocol would be preferred over another.
kokaKorina
Re: pppoe with ospf
Wed Jan 16, 2019 11:02 pm
thanks everyone
Users browsing this forum: No registered users and 13 guests
