ukzerosniper
How to prioritise traffic on Eth1 untill full then use Eth2 as overflow
Mon Jan 28, 2019 4:21 pm
Hi Guys,
Can we take two wan connections, 1 unlimited data and one limited on data and set them up as follows.
Eth1 - Unlimited data - 10Mbps Service
Eth2 - Limited data - 10Mbps Service
When Eth1 reaches 9Mbps of traffic, start sending new connections onto Eth2. When Eth1 is <9Mbps use Eth1.
Can anyone give the advice to achieve this?
I was thinking that TE Tunnels could be a viable option, but I am looking for other simpler alternatives first.
Redmor
Re: How to prioritise traffic on Eth1 untill full then use Eth2 as overflow
Tue Jan 29, 2019 12:04 am
ukzerosniper
Tue Jan 29, 2019 12:07 am
Thanks for the link.
I had a look earlier but couldn’t see a solution :/.
Could you highlight yo me the correct method?
Redmor
Tue Jan 29, 2019 12:25 am
If you can make it work go for TE, I never made it work but I think it's the best solution.
Users browsing this forum: No registered users and 6 guests
