You can make VPLS tunnel over each link and then add ECMP route to route over both tunnels.
Thanks,
I seem to ran into a different issue,
Only the first tunnel will establish.
I also tried manually specifying the transport address in LDP interface.
[admin@R1] /mpls ldp neighbor> print
Flags: X - disabled, D - dynamic, O - operational, T - sending-targeted-hello,
V - vpls
# TRANSPORT LOCAL-TRANSPORT PEER SEN
0 D TV 172.16.1.2 yes
1 D TV 172.16.0.2 yes
2 DO 1.1.1.2 172.16.0.1 1.1.1.2:0 no
[admin@R1] /interface vpls> print
Flags: X - disabled, R - running, D - dynamic,
B - bgp-signaled, C - cisco-bgp-signaled
0 R name="vpls1" mtu=1500 l2mtu=1500 mac-address=02:B2:24:43:43:72
arp=enabled arp-timeout=auto disable-running-check=no
remote-peer=172.16.0.2 vpls-id=1:2 cisco-style=no cisco-style-id=0
advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=default
1 name="vpls2" mtu=1500 l2mtu=1500 mac-address=02:B2:24:43:43:72
remote-peer=172.16.1.2 vpls-id=2:2 cisco-style=no cisco-style-id=0
