christopherh
EoIPv6 Tunnel flapping when used to route full BGP feed
Tue Mar 05, 2019 6:29 am
Hello All,
I have 2 CHRs in different locations, with an EoIPv6 tunnel between them. Each router in each location has it's own upstream peer (different ASNs), and when I try to establish a BGP session between the two CHRs, the tunnel starts flapping like a fish out of water.
I've tried filtering out of the iBGP session the external upstream v6 address prefixes (as I thought that it was trying to use the iBGP as the best route, which it couldn't do because the tunnel was established before BGP), to no avail. Does anyone have any ideas? I for the life of me, cannot work it out.
Router 1:
/ipv6 address
add address=n:n:n:491d:5400:1ff:fee3:7b24 advertise=no interface=ether1
add address=fd00:1::1/126 advertise=no interface=tun1-v6
/interface eoipv6
add ipsec-secret=abc123blah local-address=n:n:n:491d:5400:1ff:fee3:7b24 loop-protect-disable-time=0s loop-protect-send-interval=0s mac-address=nn:nn:nn:nn:nn:nn name=tun1-v6 remote-address=n:n:n:67::1 tunnel-id=2002
/routing bgp peer
add address-families=ipv6 disabled=yes hold-time=5m in-filter=IMPORT-ASnn8510-V6 instance=ASnn8510 name=ASnn8510-LON-V6 out-filter=EXPORT-ASnn8510-V6 remote-address=fd00:1::2 remote-as=nn8510 ttl=default
Router 2:
/ipv6 address
add address=n:n:n:67::1/48 advertise=no interface=ether1
add address=fd00:1::2/126 advertise=no interface=tun1-v6
/interface eoipv6
add ipsec-secret=abc123blah local-address=n:n:n:67::1 loop-protect-disable-time=0s loop-protect-send-interval=0s mac-address=nn:nn:nn:nn:nn:nn name=tun1-v6 remote-address=n:n:n:491d:5400:1ff:fee3:7b24 tunnel-id=2002
/routing bgp peer
add address-families=ipv6 disabled=yes hold-time=5m in-filter=IMPORT-ASnn8510-V6 instance=ASnn8510 name=ASnn8510-SYD-V6 out-filter=EXPORT-ASnn8510-V6 remote-address=fd00:1::1 remote-as=nn8510 ttl=default
Thanks,
Christopher H.
mrz
Re: EoIPv6 Tunnel flapping when used to route full BGP feed
Tue Mar 05, 2019 11:03 am
You are establishing BGP over the tunnel, BGP installs routes and tries to route traffic over the tunnel including tunnel traffic itself, which causes internal loop. Add static route to tunnel remote end to fix the problem.
christopherh
Tue Mar 05, 2019 1:56 pm
When you say "Add static route to tunnel remote end", (using Router 1 as the example,) what prefix am I creating the route for, and what would the gateway address be?
mrz
Tue Mar 05, 2019 3:27 pm
dst=n:n:n:67::1 you should know the gateway to your ISP. It is impossible to guess from your provided config.
christopherh
Wed Mar 06, 2019 12:53 am
And if the carrier is using ND for gateway assignment, I'd simply select the interface in place of adding the gateway? The tunnel still flaps, about once every 5 to 10 mins, not ping-pong like before. Any further ideas?
Users browsing this forum: Bing [Bot] and 4 guests
