MUM Europe 2020
Sn1p3r
PPTP problem - empty winbox
Sat Mar 09, 2019 11:25 am
Hello!
I got my home Mikrotik connected to Mikrotik at my work via PPTP connection.
All routes are made how it should, and it even worked before.
From home I can ping all devices on network, even the PPTP server Mikrotik.
When I try to connect to ANY Mikrotik at my work via I just got empty winbox, and it disconnects me after couple of seconds.
When I connect with my PC directly to PPTP Mikrotik server, everything works how it should.
What could be the issue? :)
mrz
Re: PPTP problem - empty winbox
Mon Mar 11, 2019 9:17 am
MTU issue, set up mangle rules to reduce TCP MSS.
Sn1p3r
Mon Mar 11, 2019 3:37 pm
On which device I should set this?
I tried setting on both server and client, but still no luck.
nostromog
Mon Mar 11, 2019 4:37 pm
Ensure that your firewall is allowing GRE related connections. If you don't it will not work
Enviado desde mi Redmi Note 5 mediante Tapatalk
Sn1p3r
Mon Mar 11, 2019 9:48 pm
I put my MAX MTU on PPTP connection to 1400 and it works great now.
It was 1450 before.
mjurman
Mon Mar 11, 2019 11:19 pm
/ip firewall filter add chain=input protocol=gre action=accept
GRE overhead 24 bytes -> 1500 - 24 = 1476 MTU, but you should adjust mangle to change MSS
Sn1p3r
Re: PPTP problem - empty winbox  [SOLVED]
Sat Mar 23, 2019 11:10 pm
I put my MTU lower (1400) for PPTP connection and it works great!
thomsen
Fri Apr 12, 2019 11:49 am
Thank you for advice!
After change MTU and MRU for L2TP connection bandwidth test is working both ways
Users browsing this forum: No registered users and 9 guests
