matrix98053
joining two locations
Tue Mar 12, 2019 9:04 am
Good day,
I need some help please.
I would like to join two locations and make them share one ip range.
Both locations have MT routers installed.
They can ping each others WLAN ip's
How do i go about that?
Thanks in advance
kangarie
Re: joining two locations
Tue Mar 12, 2019 9:47 am
christopherh
Re: joining two locations  [SOLVED]
Tue Mar 12, 2019 12:21 pm
Hi there,
It is quite simple to achieve this - all you need to do is create an EoIP tunnel between the two routers, and place the interfaces on each side into a bridge. Ensure that you don't have DHCP enabled on both sides (only set it on one side) and you're done!
Thanks,
Christopher H.
matrix98053
Wed Mar 13, 2019 3:45 pm
Thank you for the help.
I managed to get it working with Eoip tunnel.
I will go test it at the other site tomorrow.
Regards
matrix98053
Wed Mar 13, 2019 3:46 pm
Thank you, I managed to get it working.
Users browsing this forum: No registered users and 7 guests
