ppcarvalhof
OSPF(v2 andv3) nssa: only one role translator?
Tue Apr 02, 2019 5:46 pm
Why only in MikroTik i can't run more of one nssa role translator? In my scenario, i want "stuck" CEs into your own nssa area (because each one receive only default-route from PE and announces that own prefix through static routes). When has two or more CEs on PE, i create an nssa area to each CE but, i can't make PE role translator for more of one nssa area. Why? If i create same scenario with cisco PE, thats works fine...
That is error
Couldn't add New OSPF Area - only one area is allowed to be NSSA translator (6)
TheCiscoGuy
Re: OSPF(v2 andv3) nssa: only one role translator?
Wed Apr 10, 2019 12:13 am
According to RFC 3101, Sectio 3.1 there is a concern by the author that multiple NSSA borders performing LSA-7 to LSA-5 translations would cause excessive numbers of type 7 translations resulting in increasing the LSDB unnecessarily. It does not say that the act of prohibiting multiple translators is a requirement, but is strongly advised against. It is likely that Mikrotik has taken it upon themselves to prevent a possible misconfiguration and restricted the number of translators in the firmware directly.
Network Solutions Engineer and Trainer
Cisco | Juniper | Mikrotik | Ubiquiti
TheCiscoGuy
Wed Apr 10, 2019 12:15 am
One thing to note, if you are (judging by the diagram provided) using OSPF for dynamic routing to the CE and wish to use OSPF NSSA to effectively inject a default route to the CE, a better option would be either to create a new OSPF process which only advertises a default or even better use BGP
Users browsing this forum: funkydizzle and 7 guests
