Paternot
Long time Member
Long time Member
Output of "/routing bgp advertisements print" is truncated
Tue Apr 09, 2019 5:25 am
When dealing with IPv6 routes, the output of the command "/routing bgp advertisements print" is truncated: "PEER", "PREFIX" and "NEXTHOP" aren't big enough to display the output. Is it a bug? Or is there some parameter I can pass to solve it?
PEER     PREFIX               NEXTHOP          AS-PATH                                            ORIGIN     LOCAL-PREF
Escri... fdfd:fd00:0:2010:... fdfd:fd00:0:2...                                                    incomplete
Escri... fdfd:fd00:0:2010:... fdfd:fd00:0:2... 4200000007                                         incomplete
I'm running RoS 6.44.2
pe1chl
Re: Output of "/routing bgp advertisements print" is truncated  [SOLVED]
Tue Apr 09, 2019 2:47 pm
This is kind of common to all command-line access to RouterOS: the column width is fixed.
I am not aware of a way around that in commandmode.
You can either use winbox or webfig, or use API to retrieve this info to another system where you can print it the way you like.
Paternot
Long time Member
Long time Member
Tue Apr 09, 2019 5:07 pm
That's... disappointing. But thanks for the suggestions. :D
CZFan
Sun Apr 28, 2019 3:21 am
Have you tried accessing the device with ssh and then run command?
MTCNA, MTCTCE, MTCRE & MTCINE
Paternot
Long time Member
Long time Member
Sun Apr 28, 2019 3:26 am
That's exactly through SSH that I did this...
sri2007
Tue Apr 30, 2019 5:38 am
Hi!! Seems like we're not able to use the export to a file either :( the result is truncated too.
MikroTik Soporte y Consultoría - Español / English +593 98 709 3502
https://www.safenet.ec/consultoria.html/ soporte@safenet.ec
Users browsing this forum: No registered users and 16 guests
