Dude2048
Multicast
Thu Jun 20, 2019 3:25 pm
I tried to create a test multicast network. Example is below. When I start an RTP stream on the VLC server I can pick it up localy. So that is running The stream uses an address of 224.0.1.1. However the client won't connect to the stream on the server. When I setup a simple bridge with two ports in it, the stream will run, obviously. There is something with the layer 3 config, I think...
I read the Wiki on the site, viewed MUM demo's and so on. Is there anyone who can help me to get a bit further.
RB1100
add address=192.168.1.254/24 interface=ether1 network=192.168.1.0
add address=192.168.6.254/24 interface=ether6 network=192.168.6.0
add distance=1 dst-address=192.168.2.0/24 gateway=192.168.6.1
/routing pim interface
add alternative-subnets=192.168.2.0/24,192.168.6.0/24
/routing pim rp
CCR
add address=192.168.2.254/24 interface=ether2 network=192.168.2.0
add address=192.168.6.1/24 interface=ether6 network=192.168.6.0
add distance=1 dst-address=192.168.1.0/24 gateway=192.168.6.254
/routing pim rp
Dude2048
Re: Multicast
Sun Jun 23, 2019 11:06 am
Bump
Prewest
Re: Multicast
Sun Jun 23, 2019 11:19 am
I`m missing the forward rule in the firewall, I don`t know the command out of my head but it should be
Firewall -> add rule -> forward -> DST-Adress = 224.0.0.0/4 -> -> in interface / out interface -> action accept or passthrough..
Dude2048
Re: Multicast
Sun Jun 23, 2019 1:10 pm
There are no firewall rules what so ever. The only config on the routers is that what you see.
But thank you vert much for thinking about it
kakaxa
Re: Multicast
Sun Jun 23, 2019 7:01 pm
try
Chiverel
Re: Multicast  [SOLVED]
Mon Jun 24, 2019 10:39 am
There's a chance that you have packets with TTL=1. If you have them, you can increase TTL using mangle.
I recall it was explicitly mentioned for VLC when tried to configure my setup.
Check this example as well, it has nearly yours case.
Dude2048
Re: Multicast
Mon Jun 24, 2019 11:57 am
Thanks, I will test the solitions in a day or two and let know if it is resolved.
Dude2048
Re: Multicast
Mon Jun 24, 2019 9:01 pm
Thanks TTL it is!!!!
pe1chl
Re: Multicast
Mon Jun 24, 2019 10:43 pm
Is it not possible to configure the TTL in VLC?
Dude2048
Re: Multicast
Tue Jun 25, 2019 9:30 am
From what I have read, no. There is something in VLC that is preventing that.
Users browsing this forum: No registered users and 5 guests
