Gombeen666
OSPF Interface all passive
Thu Jun 27, 2019 12:27 pm
When setting ospf interface "all" as passive is it normal that state is "Down"
1 P interface=all cost=10 priority=1 authentication=none authentication-key=""
authentication-key-id=1 network-type=broadcast instance-id=0
retransmit-interval=5s transmit-delay=1s hello-interval=10s
dead-interval=40s use-bfd=no
Anumrak
Re: OSPF Interface all passive
Thu Jun 27, 2019 3:34 pm
You should do passive interfaces if you do not want to enable OSPF on them.
Wolfraider
Tue Jul 16, 2019 2:18 am
I wish there was a simple way to mark all instances as passive except the ones we add manually.
Anumrak
Tue Jul 16, 2019 11:06 am
Its easy enough with winbox software as a GUI.
IPANetEngineer
Trainer
Trainer
Tue Jul 16, 2019 4:36 pm
Are you saying the interfaces are physically up but show as down in OSPF passive?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Wolfraider
Tue Jul 16, 2019 10:23 pm
Not as easy when you have a few hundred vlans. Not bad to script but would be nice to have a simple checkbox to automatically have all interfaces as passive and then add the ones you want.
jprietove
Trainer
Trainer
Wed Jul 17, 2019 9:59 am
/routing ospf interfaces add interface=all area=backbone passive=yes
Anumrak
Wed Jul 17, 2019 10:33 am
Exactly :)
https://wiki.mikrotik.com/wiki/Manual%3 ... #Interface
jprietove
Trainer
Trainer
Wed Jul 17, 2019 11:05 am
Well, not exactly because this is not OSPF-v3... it is (sorry for the mistake):
/routing ospf interface add interface=all passive=yes
Wolfraider
Thu Jul 18, 2019 2:12 am
I completely missed that. Thanks
Users browsing this forum: No registered users and 16 guests
