Gombeen666
Some OSPF commands not working on V6.45.2
Thu Jul 25, 2019 6:37 pm
https://wiki.mikrotik.com/wiki/Manual:Routing/OSPF
/routing ospf monitor
Does not work!
/routing ospf ospf-router
Does not work!
From reading Cisco OSPF - "show ip ospf" or "show ip ospf interface brief" - what are the Mikrotik equivalents !
mrz
Re: Some OSPF commands not working on V6.45.2
Thu Jul 25, 2019 6:46 pm
v6 is multi instance OSPF. From the manual:
"Since v3.17 it is possible to run multiple OSPF instances. General OSPF configuration now is moved to instances."
and
"For multi instance OSPF you have to use following command: /routing ospf instance print status"
Gombeen666
Thu Jul 25, 2019 9:37 pm
OK - what command will tell me what OSPF function the router is (IR, Backbone, ABR, ASBR )
nichky
Long time Member
Long time Member
Fri Jul 26, 2019 12:30 am
/routing ospf lsa> print detail where type=
/routing ospf as-border-router
/routing ospf area-border-router
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
Gombeen666
Fri Jul 26, 2019 10:02 pm
I am asking if Mikrotik will give me OSPF detailed info like the way Cisco does?
Users browsing this forum: No registered users and 2 guests
