interlan
OSPFv3 problem
Fri Sep 06, 2019 8:10 am
I have two CCR1036-8G-2S+ with RouterOS 6.45.5 multiple parallel/same vlan's. ( same problem with older versions )
The system log's is flooded with this
And the two get full sync in some vlan's but not in all. I think the problem is based on same EUI-64 Link-Local who i can't change and either change the mac. Creating bridges to solve the mac-problem is not an alternative here.
I have tested to change almost allt parameters with same result. Network type, stub zone with other areas etc.
Any ideas?
/ipv6 address
add address=2001:bd8:100:3901::18 advertise=no interface=v3901
add address=2001:bd8:100:3906::18 advertise=no interface=v3906
add address=2001:bd8:100:3902::18 advertise=no interface=v3902
/routing ospf-v3 interface
add area=backbone interface=v3901
add area=backbone interface=v3902
add area=backbone interface=v3906
IPANetEngineer
Trainer
Trainer
Re: OSPFv3 problem
Sat Sep 07, 2019 5:00 pm
I believe this problem was discussed here:
viewtopic.php?f=14&t=151650
The workaround was to run two OSPF instances since there is no way to change the link local
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
interlan
Re: OSPFv3 problem
Mon Sep 09, 2019 8:27 am
I have tried multiple instances, area id, stub area etc but there are always same problem.
Users browsing this forum: No registered users and 10 guests
