MUM Europe 2020
kingportipher
UNABLE TO PING OVER EOIP TUNNEL
Fri Sep 06, 2019 1:27 pm
Hello Team,
Please i have configured eoip over the internet to two mikrotik routers: LHG R and 1100 routers.
The tunnel is UP but the host machines connected are unable to ping each other.
Attached is the diagram.
Kindly assist
pwuk
Re: UNABLE TO PING OVER EOIP TUNNEL
Fri Sep 06, 2019 2:51 pm
So on each router you have an eoip interface, a physical port, and a bridge that contains both?
I'm guessing there's no entry in the arp tables?
sebaShannon
Tue Sep 17, 2019 5:26 pm
You have to make sure that EoIP interface is bridged with ether1 on LHG and with interface connected to 10.10.10.1 on RB1100.
That's obviously if you want to have them in the same broadcast domain.
IPANetEngineer
Trainer
Trainer
Thu Sep 19, 2019 6:27 pm
Can you share your config?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
vegas2428
Tue Oct 08, 2019 10:25 am
if u haven't bridge the LTE interface, then you must add a route of the LAN IP of LHG to the router with the gateway of LHG EoIP Tunnel.
Users browsing this forum: No registered users and 9 guests
