kical
HTTP Downloads cancels when LDP enabled
Sun Oct 06, 2019 1:22 am
Hi Im having a Issue from 3 months ago could not resolve it and had searched on the web without any clue.
I have the following topology
Need to activate MPLS on the network for giving customers services like l3 vpn.
My problem is that when I have a customer from site 78 via a wireless link and I activate LDP on Site 80 every https / http downloads cancels giving out the error "Network Error"
I have notice that when I disable there's not issue whith downloads any single.
Running ROS: 6.44.5
From Site 80 I have OSPF to other sites I have
I have enabled Jumbo Frame on PTP links, Checked the Switch Configurations and MTU are set to 9216 on the switches.
here are some ss from the configurations
Site 80
Site 78
The Vlans from the PTP has 9000 MTU Configured
IPANetEngineer
Trainer
Trainer
Re: HTTP Downloads cancels when LDP enabled
Tue Oct 08, 2019 4:12 pm
Typically the issue you are describing indicates a problem with MTU somewhere.
What are your MTU settings for.
L2
L3
MPLS
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
kical
Mon Oct 14, 2019 1:47 am
I setup the following
CCR1009
On the Trunk Interface:
L3 MTU:1500
L2 MTU: 1580
MPLS MTU: 1530
On the vlan Is has
L3 MTU: 1500
L2 MTU(Autoconfigure to): 1576
AirFiber: JumboFramce Activated on both PTP
Site 1 Edgepoint S16: MTU on all interfaces 9216
Site 2 EdgeSwitch; MTU on all interfaces 9216
Test of ping of 1472 + 28 =1500
Error from chrome
When I shutdown LDP on Site A I accomplish the download
IPAsupport
Mon Oct 14, 2019 7:17 pm
The first thing I would do is connect a router locally to Site 80 that isn't over the wireless link, enable MPLS and see i it's still an issue.
Does this hapen to all HTTP/HTTPs sites or only some of them?
mducharme
Trainer
Trainer
Tue Oct 15, 2019 7:37 am
What is your advertise filter set to?
kical
Sun Oct 20, 2019 5:22 am
I got 10.0.0.0/24 advertise yes
0.0.0.0/0 advertise no
Is setup on all routers, our forwarding table carries all labels for loopbacks
Users browsing this forum: Google [Bot] and 9 guests
