uldis
OpenFlow feature?
Mon May 18, 2020 11:13 am
We would like to understand if the OpenFlow protocol is still in the use for the network operators and if there are lot of use-cases where is it widely used and if there would be benefits that we could upgrade the OpenFlow implementation in RouterOS from v1.0 to v1.3?
Or we need to look for newer version implementation?
IPANetEngineer
Trainer
Trainer
Re: OpenFlow feature?
Mon May 18, 2020 4:42 pm
OpenFlow is still very much in use! ISPs, Internet Exchanges and Data Centers all have use cases for OpenFlow. There is a fantastic open source controller called Faucet that is easy to get up and running.
https://faucet.nz/
We have been working on a project to use OpenFlow to manage traffic engineering in Wireless ISPs and went to Google's HQ last fall for FaucetCon to present that work. Video is here:
https://www.youtube.com/watch?v=HyFXpEJ ... 1z&index=4
Unfortunately we couldn't use MIkroTik equipment because it wasn't at least ver 1.3 :(
Please implement this!!
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
buraglio
Mon May 18, 2020 4:53 pm
Seconded. Faucet is unquestionably the de facto standard for doing openflow correctly in a production-ready and scalable way. They have a test suite that validates the vendor implementation making sure it's successful and supports all of the right components - the keys being multi-table and next-table. Please implement this, I'm willing to help test, and I will all but guarantee that the Faucet developers will aid as they have done with many other vendors (HPe, Arista, Cisco, ATI, NoviFlow, etc..)
An example of a very successful deployment at massive scale can be heard about here:
https://blog.ipspace.net/2019/04/using- ... -with.html
ForwardingPlane, LLC
https://www.forwardingplane.net
josmon
Mon May 18, 2020 7:06 pm
It would be boon to many to have a Faucet compliant OpenFlow implementation within RouterOS. It would bring reasonably priced gear within reach of many that are interested in OpenFlow.
Including such a feature will surely increase the demand for RouterOS products.
Hammy
Forum Veteran
Forum Veteran
Mon May 18, 2020 7:08 pm
I look forward to implementing a Faucet-controlled OpenFlow network, per the work Sajan, Kevin, Nick, and Adair have been doing.
Mike Hammett
The Brothers WISP
bradcowie
Tue May 19, 2020 5:23 am
Hi all - Brad here one of the project leads over at the faucet project, a lightweight opensource enterprise controller for the enterprise.
A number of our users pointed me at this thread and asked if I could post a message.
We at the faucet project are happy to help any vendor who wants to implement OpenFlow 1.3 support, we have an automated test suite that will qualify vendor devices for faucet support and I have worked with 3 or 4 vendors directly now to help them implement support on their devices.
If this sounds interesting, let me know!
marcperea
Trainer
Trainer
Tue May 19, 2020 7:00 pm
When I was building a Brocade/Cisco SDN in 2015 for an ILEC telco using opendaylight, I wanted to incorporate Mikrotik to the SDN at the access and customer edge portions of the network - however due to lack of support for current openflow standards to match frames/packets for my flows and direct/rewrite across a service provider network, I abandoned Mikrotik as a contender on this platform.
We built a programmable network where customers could self service and adjust the particulars of their broadband, VPN, VOIP and IPTV service delivery from a portal that auto-provisions these changes without need for waiting on human service order fulfillment, so long as facilities were already available, taking order delivery from days (or weeks, sometimes) down to near instantly applied.
1.3 would've been sufficient for this use case (and stuff I've been working on since then).
Turbocharge your Internet!
http://aerez.net
nz_monkey
Wed May 20, 2020 2:41 am
It would be fantastic if Mikrotik gave OpenFlow some focus and updated it to OpenFlow 1.3
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
chebedewel
Fri Jun 26, 2020 8:24 am
Yes ! would love an upgrade to v1.3 ^_^
Bertrand Cherrier
MTCNA - MTCTCE
_______________________________________________________
MikroTik Consultant & Distributor for New Caledonia
noucom
Mon Jul 20, 2020 4:14 pm
Agree : +1
infrastation
Sun Aug 16, 2020 12:33 am
Hello MikroTik folks, thank you for asking. Let me try to answer your question.
I have been working with network protocols for many years. When OpenFlow switches started to become generally available about 2012-2013, I took an OF 1.0 controller and tried to make assorted OF switches work with it to implement a few applications, with varying success. Also I tried to test stability, capacity, performance, spec conformance and feature set of each OF switch.
When the applications, the controller or the switches crashed for no apparent reason, it was important to understand what is going on on the wire. At that time packet analysers had no support for OF out of the box so I had implemented OF 1.0 decoding in tcpdump. With the decoded protocol exchange I typically either fixed a bug in the controller, or filed a bug report with the switch vendor.
In total I had closely studied hardware OF switches of 7 vendors (mostly brand name) in a lab with actual cables and servers, with 2 more vendors I had only a brief brush. The MikroTik implementation had the most faults and yielded the most bug reports. AFAIR, at least half of these bug reports quietly died somewhere on the MikroTik tech support side of the fence. This is not to offend anyone, but to convey essential facts in support of my point below.
On the upside, RouterBoard was undoubdetly the cheapest, also I found ways to work around the implementation faults in one specific application that required only 4 dataplane ports per OF switch and tolerated low bandwidth (MikroTik OF 1.0 was software-only at the time). So I bought a bag of RouterBoards and worked on that application for a while until much more important things kicked in.
Fast-forward to 2020, if MikroTik adds support for OF 1.3 anytime soon, I still have that bag of RouterBoards and it could be fun to rig something up using the aforementioned Faucet, as a possible example. But please mind that it would likely result in new faults and new bug reports, and if MikroTik just disregards these as before, it will work against the success of the product.
brotherdust
Tue Sep 08, 2020 10:53 pm
Uldis,
I think it's obvious from this thread that there's still an interest in OpenFlow. One of the things, I think, that is holding back some adoption is that Mikrotik's implementation doesn't support OpenFlow 1.3 with multiple tables. In the time since Mikrotik released an OpenFlow package for RouterOS, controller software has continued to mature and, I think, Faucet is a good candidate for being the de-facto standard here. I would very much LOVE to see this happen. Even if it's just on the CRS-3xx series, that would be fine. IIRC, the chipset for the CRS-3xx series has OpenFlow support, so it doesn't seem to be a HUGE investment to make that happen.
What's your thoughts on this, Uldis? Should we have hope Mikrotik will do this?
Users browsing this forum: mixig and 10 guests
