leostereo
Traffic control over redundant topology (conceptual).
Fri Aug 07, 2020 4:32 pm
Hi guys.
Please consider following scenario:
I would like to be able to fully manage traffic over links, so I can automatically balance traffic or manually stear among all the possible paths.
For example,
I would like to send traffic from R1 to R3 like this:
Automatically or manually forcing 25% over all links, direct links E,F and through R2 with A andB links..
or
Automatically or manually forcing 50% and 50% over direct links E and F.
or
Automatically or manually forcing 50% and 50% over links A and B through R2.
Is it possible to accomplish such control?
Some options Im considering are.
lacp with AB , CD and EF.
pro: easy implementation.
con: poor balance control and link monitoring
mpls:
pro: Can implement vpls and TE.
improve performance.
con: mkt does not support fast re-route.
complex debug and implementation.
OSPF:
any idea ? (Currently studing)
BGP
any idea? (currently studing)
Other:
EOIP: ?
Ok ... hope to be crear about my goal.
Thanks.
IPANetEngineer
Trainer
Trainer
Re: Traffic control over redundant topology (conceptual).  [SOLVED]
Sat Aug 08, 2020 4:35 pm
Here is one method of traffic engineering that works very well with MikroTik. From a presentation I did at the MIkroTik US MUM in 2017
https://mum.mikrotik.com/presentations/ ... 062656.pdf
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
Users browsing this forum: No registered users and 8 guests
