andrewe02000
Redundant BGP With Redundant Routers VIA VRRP Need Help
Thu Aug 13, 2020 7:29 pm
I have R1 and R2 routers that have VRRP setup on ether1 on which BGP will occur with the ISP. The ISP have initialized a BGP1 session with its own /30 IP range and a secondary BGP2 session with its own separate /30 IP range. How can I setup two separate VRRP interfaces so that on R1 BGP1 is on VRRP1 interface in master mode and BGP2 is on VRRP2 interface in backup mode while on R2 BGP1 is on VRRP1 interface in backup mode and BGP2 is on VRRP2 interface in master mode? That way each router always has an active BGP route table of the internet.
Cha0s
Re: Redundant BGP With Redundant Routers VIA VRRP Need Help
Fri Aug 14, 2020 1:36 pm
You don't need VRRP if you already have 2 BGP sessions with your upstream.
Just ditch VRRP on the public side (ether1), and do 1 BGP peering on each of your routers.
BGP will take care of failover, etc.
You can also use BGP MED to control which router will be the "primary" (ie: on which router you will receive incoming traffic).
Take a look on this MUM presentation https://mum.mikrotik.com/presentations/ ... _Nikos.pdf
fenomen51
Sat Aug 15, 2020 12:47 am
What about the delays? BGP has significant
Cha0s
Sun Aug 16, 2020 1:37 am
On the one hand, using VRRP the way OP described, will not necessarily make failover any faster, if for example the physical link stays up but it doesn't pass any traffic.
Even if you failover on your end, the other end will still have to timeout before using the routes from the other BGP peer.
On the other hand, you can use BFD (which is supposedly the proper method for fast failure detection).
Beware though, BFD on ROS does not play well (or at all) with other BGP vendors (or even with ROS).
Another option (which is described in the MUM presentation) would be to use VRRP on the "lan" side and use scripting on master/backup states to change the BGP MED so that the upstream will quickly use the routes your the second router even if the BGP peering with the first router hasn't timed out yet.
andrewe02000
Mon Aug 24, 2020 8:14 pm
Tank you for the feedback. I am probably going to try a few different setups to see what works the best. Unfortunately I am having issues with MTU with VRRP with CHR where you cant set the MTU on the VRRP interface higher than 1500 or on any sub interfaces such as VLANS. Support was able to reproduce the problem so until they have a fix I'll be putting this project on the side. I look forward to trying the suggestions once they fix the VRRP MTU issue.
IPAsupport
Tue Aug 25, 2020 5:01 am
Instead of combining VRRP and BGP which normally isn't recommended, consider using this design with BFD which is simlilar to what you're asking for
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Users browsing this forum: No registered users and 16 guests
