leostereo
BGP Load Balancing with two interfaces
Wed Aug 26, 2020 7:56 pm
Hi , guys , after looking at following link:
https://wiki.mikrotik.com/wiki/Manual:B ... interfaces
Have following feelings:
Is it really doing load balance between both links or just automatic failover ?
Is there any other working example to analize ?
Comparing this method with bonding , have following conclusion:
2 bpg peers:
pro: Can manually select with link to use.
con: more rosurces , using two bgp sessions.
1 bpg peer and two links in bonding.
pro: Automatic balancing.
con: poor monitor control , for example, can not force ping per link.
Others ?
Thanks.
Leandro.
IPANetEngineer
Trainer
Trainer
Re: BGP Load Balancing with two interfaces
Wed Aug 26, 2020 8:51 pm
If you can bond the links, it's much simpler and you should use LACP.
BGP Load balancing is for use cases when bonding is not possible.
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
Users browsing this forum: No registered users and 14 guests
