SolidProfession
Winbox ports
Fri Sep 25, 2020 8:17 pm
I'd like to access my switch through my firewall's DDNS service ie: firewall.ddnsprovider.com:xxxx
Where xxxx is the "port"
I know how to make that possible on the firewall end, but not sure what port Winbox requires? Then it means I can access it anywhere, and it would be easy to control from well, any where
anav
Re: Winbox ports
Fri Sep 25, 2020 8:19 pm
Then it would not be a firewall but a security risk. ( a weak professional '-p )
Access to your router via the internet should be done via VPN.
Anything else is not recommended.
SolidProfession
Re: Winbox ports
Fri Sep 25, 2020 8:27 pm
Eh. I'd enable / disable the VIP as and when is required. I also would do that but I don't have a firewall on this side of things
Sob
Re: Winbox ports  [SOLVED]
Fri Sep 25, 2020 10:05 pm
If you didn't change it (in IP->Services), default for WinBox is tcp port 8291.
Users browsing this forum: No registered users and 11 guests
