j2sw
Modern IBGP design questions
Tue Oct 06, 2020 4:13 pm
Want to see what folks are doing in this scenario.
Two Mikrotik Routers. Each has an ISP pulling in default routes via eBGP.
Are you doing a separate instance to establish iBGP? If so, are you doing "redistribute Other bGP" in the instance? Client to CLient reflection?
in the peer are you doing nexthop choice "force self, propagate, or leaving at default"?
Using route reflect in the peer?
IPANetEngineer
Trainer
Trainer
Re: Modern IBGP design questions
Tue Oct 06, 2020 4:21 pm
A few thoughts here.
1) You don't want separate instances...that would require redistribution and isn't needed
2) You want a router that isn't a border to act as a route reflector often these are core routers - this can even be out of path like a CHR
3) You need to either set next-hop-self on each border router peering to the RR or advertise the PTP subnet of the upstream into OSPF
4) You only need route reflection turned on at the route reflector - the downstream clients need no special config
Here is a drawing and overview of this type of design with IPv4
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
Users browsing this forum: No registered users and 15 guests
