bokbok
OSPF2 network-type
Thu Oct 15, 2020 8:44 am
sorry for noobish question - my very first on this forum: I'm curious if there is a plan to introduce OSPF network type which would not use multicast nor elect DR and BDR. My intention is to use this network type for ptp links over a network (including wireless peers) which do not support multicast.
If not, are there any recommendation which network-type use in such cases?
Regard, Martin
mrz
Re: OSPF2 network-type
Thu Oct 15, 2020 10:40 am
In RouterOS v6 only network type that works without multicast is NBMA.
bokbok
Fri Oct 16, 2020 11:51 am
Thank you for the reply. Unfortunately I know that. I'm looking for something like NBMA but without using DR/BDR at all - like ptmp and point-to-point do.
IPANetEngineer
Trainer
Trainer
Fri Oct 16, 2020 5:10 pm
I'm curious, what is the intent behind not wanting DR/BDR?
You might consider eBGP for RF links. It converges pretty fast and doesn't require multicast
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
bokbok
Fri Oct 16, 2020 10:51 pm
I just feel they are unnecessary for ptp link.. and the DR/BDR election may increase the time needed to recover after a failure. Thank for your advice anyway, I'll definitely give eBGP a look!
IPANetEngineer
Trainer
Trainer
Sat Oct 17, 2020 5:58 pm
That's why we normally use the ptp OSPF type on RF links and it works very well with rapid convergence.
What radios are you using that don't support multicast?
Users browsing this forum: bdash and 14 guests
