linkomatas
VPN routes
Fri Oct 23, 2020 9:22 am
I'm kind of struggling with IP sec site-to-site VPN traffic. A little bit of background, VPN itself is established, but I can't ping between routers and between netowrks. But if I ping from site A computer to site B computer then traffic flows fine. Reboot routers and then traffic dies but if I ping again from computers from different sites, traffic flows fine again. I don't think that it should be this way since I need to ping each time if I want traffic to flow trough tunnel :D
My other thoughts is because of network 192.168.0.0/24. I'm thinking of changing it to something else 192.168.2.0/24 e.g. But I'm not sure if that may help.
I tried to config VPN routes but all I get is timeout. looking forward for some tips. Thanks.
For better understanding, below is my config:
Site A:
# oct/23/2020 09:13:10 by RouterOS 6.47.4
# software id = RLRF-39GH
# model = 2011UiAS-2HnD
# serial number =
add admin-mac= auto-mac=no comment=defconf fast-forward=no \
    name=bridge
add fast-forward=no name=bridge-voip protocol-mode=none
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] loop-protect=on name=ether2-master speed=\
    100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=\
    ether6-master
set [ find default-name=ether7 ] advertise=\
set [ find default-name=ether8 ] advertise=\
set [ find default-name=ether9 ] advertise=\
set [ find default-name=ether10 ] advertise=\
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    country=lithuania disabled=no distance=indoors frequency=auto mode=\
    ap-bridge ssid=Teo-F53A3B-Greitasis station-roaming=enabled \
    wireless-protocol=802.11
/interface vlan
add interface=ether1 name=vlan5-ext vlan-id=5
add interface=ether10 name=vlan5-int vlan-id=5
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=BEA0B08F7A \
    wpa2-pre-shared-key=BEA0B08F7A
/ip ipsec peer
add address= exchange-mode=ike2 name=
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 \
    hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc \
    pfs-group=modp2048
add name=dhcp ranges=192.168.1.15-192.168.1.200
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
    bridge name=defconf
/ppp profile
add local-address=10.30.0.1 name=ovpn remote-address=10.30.0.2
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=ether6-master
add bridge=bridge comment=defconf hw=no interface=sfp1
add bridge=bridge-voip interface=vlan5-ext
add bridge=bridge-voip interface=vlan5-int
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
set discover-interface-list=discover
add interface=sfp1 list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=ether6-master list=discover
add interface=ether7 list=discover
add interface=ether8 list=discover
add interface=ether9 list=discover
add interface=ether10 list=discover
add interface=wlan1 list=discover
add interface=bridge list=discover
add interface=vlan5-ext list=discover
add interface=vlan5-int list=discover
add interface=bridge-voip list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1 certificate=CA cipher=aes128 default-profile=ovpn enabled=yes \
    port=52210
add address=192.168.1.254/24 interface=ether2-master network=192.168.1.0
add address= interface=ether1 network=
/ip dhcp-server lease
add address=192.168.1.117 always-broadcast=yes mac-address=
add address=192.168.1.189 mac-address=
add address=192.168.1.0/24 comment=lan dns-server=\
    212.59.1.1,212.59.2.2,8.8.8.8 gateway=192.168.1.254 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.1.254 name=router
/ip firewall address-list
add address= disabled=yes list=
add address= list=
add action=accept chain=input dst-port=52210 protocol=tcp
add action=accept chain=input comment="defconf: accept established,related" \
add action=accept chain=input disabled=yes src-address=91.224.135.250
add action=accept chain=input dst-port=8291 protocol=tcp src-address-list=\
    GBSistemos
add action=accept chain=input disabled=yes in-interface=*F00002
add action=drop chain=input comment="defconf: drop all from WAN" \
    in-interface=ether1
add action=accept chain=forward comment="defconf: accept established,related" \
add action=accept chain=forward disabled=yes in-interface=*F00002 \
    out-interface=bridge
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=accept chain=srcnat dst-address=192.168.0.0/24 src-address=\
    192.168.1.0/24
    out-interface=ether1
add action=dst-nat chain=dstnat comment=8080 dst-port=8080 in-interface=\
    ether1 protocol=tcp to-addresses=192.168.1.243 to-ports=80
add action=dst-nat chain=dstnat comment="NVR" dst-port=37777 \
    in-interface=ether1 protocol=tcp to-addresses=192.168.1.1 to-ports=37777
add action=dst-nat chain=dstnat comment=snd-esp dst-port=4500 in-interface=\
    ether1 protocol=udp to-addresses=192.168.1.240
add action=dst-nat chain=dstnat comment=snd-ike dst-port=500 in-interface=\
add action=dst-nat chain=dstnat comment=snd-esp2 in-interface=ether1 \
    protocol=ipsec-esp to-addresses=192.168.1.240
add action=dst-nat chain=dstnat disabled=yes dst-port=8292 in-interface=\
    ether1 protocol=tcp src-address-list=adminai to-addresses=192.168.1.240 \
    to-ports=8291
add action=dst-nat chain=dstnat dst-port=37781 in-interface=ether1 protocol=\
    tcp to-addresses=192.168.1.33 to-ports=37781
add action=dst-nat chain=dstnat dst-address= dst-port=443,5001 \
    protocol=tcp to-addresses=192.168.1.10 to-ports=5001
add action=dst-nat chain=dstnat dst-address= dst-port=6690 \
    in-interface=ether1 protocol=tcp to-addresses=192.168.1.10 to-ports=6690
add action=masquerade chain=srcnat dst-address=192.168.1.0/24 src-address=\
    192.168.1.0/24
/ip ipsec identity
add peer=secret=
/ip ipsec policy
add dst-address=192.168.0.0/24 peer= sa-dst-address= \
    sa-src-address= src-address=192.168.1.0/24 tunnel=yes
add distance=1 gateway=
add disabled=yes distance=1 dst-address=192.168.0.0/24 gateway=bridge \
    pref-src=
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/lcd pin
set pin-number=4455
/lcd interface pages
set 0 interfaces="sfp1,ether1,ether2-master,ether3,ether4,ether5,ether6-master\
    ,ether7,ether8,ether9,ether10"
/ppp secret
add name=rem1 password= profile=ovpn
/system clock
set time-zone-name=
/system ntp client
set enabled=yes primary-ntp= secondary-ntp=
/system scheduler
add name="upgrade OS" on-event=":log info (\"Rebooted Mikrotik. Installing upd\
    ates...\")\r\
    \n:delay 2s;\r\
    \n/system reboot" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=oct/17/2020 start-time=02:06:08
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool sniffer
set filter-interface=*F00002
Site B:
# oct/23/2020 09:13:40 by RouterOS 6.47.4
# software id = RHKS-AFAN
# model = RBwAPGR-5HacD2HnD
# serial number =
add admin-mac= auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=lithuania disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=station-roaming=enabled \
set [ find default-name=wlan2 ] band=5ghz-a/n/ac country=lithuania disabled=\
    no installation=indoor mode=ap-bridge ssid=station-roaming=\
    enabled wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn= authentication=chap default-route-distance=1 \
    name=telia password=omni user=omni
/interface lte
set [ find ] apn-profiles=telia name=lte1 pin=
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key= \
/ip hotspot profile
/ip ipsec peer
/ip ipsec profile
/ip ipsec proposal
    pfs-group=modp2048
add name=dhcp ranges=192.168.0.10-192.168.0.100
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
add address=192.168.0.1/24 comment=defconf interface=ether1 network=\
    192.168.0.0
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1 netmask=24
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
add address= list=allow
    established,related,untracked
    allow
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=accept chain=srcnat dst-address=192.168.1.0/24 src-address=\
    192.168.0.0/24
add action=dst-nat chain=dstnat dst-port=8000 protocol=tcp to-addresses=\
    192.168.0.100 to-ports=8000
add action=dst-nat chain=dstnat dst-port=554 protocol=tcp to-addresses=\
    192.168.0.100 to-ports=554
add action=dst-nat chain=dstnat dst-port=80 protocol=tcp src-address-list=\
    allow to-addresses=192.168.0.100 to-ports=80
/ip ipsec identity
add peer= secret=
/ip ipsec policy
add dst-address=192.168.1.0/24 peer= sa-dst-address= \
    sa-src-address= src-address=192.168.0.0/24 tunnel=yes
add disabled=yes distance=1 dst-address=192.168.1.0/24 gateway=bridge \
    pref-src=192.168.1.254
/system clock
set time-zone-name=
/system ntp client
/system scheduler
add name=schedule1 on-event=":log info (\"Rebooted Mikrotik. Installing update\
    s...\")\r\
    \n:delay 2s;\r\
    start-date=oct/17/2020 start-time=01:06:52
/tool mac-server
Sob
Re: VPN routes
Fri Oct 23, 2020 5:25 pm
So, on Site A, what's 192.168.1.240 and why do you dstnat IPSec traffic to it, when you need it for this router?
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
linkomatas
Re: VPN routes
Tue Nov 10, 2020 10:39 pm
Thanks @Sob for reply. I found the problem which was incorrect firewall configuration. Now tunnel seems working fine.
Users browsing this forum: perlasnialex and 26 guests
