fr34k
Need help with Server connection/forwarding on CCR1036
Thu Nov 05, 2020 10:00 am
Hello
I need help with my CCR1036 to connect my 2 server. I have tried everything I knew but nothing works :(.
My WAN is considered to port 1 and DHCP on port 2, server 1 on port 3 and server 2 on port 4.
My question is, do I need switch or I can make it work with direct connection?
DHCP server is 192.168.1.1 and it used switch only for house devices...
Server 1 IP is 192.168.2.120
Server 2 IP is 192.168.3.212
If it is possible to make connection direct on routers port without switch, how can I do that?
Thank you for your help:)
cdiedrich
Forum Veteran
Forum Veteran
Re: Need help with Server connection/forwarding on CCR1036
Thu Nov 05, 2020 1:21 pm
Let's assume your servers are configured in a /24 subnet and .1 of this subnet is their default g/w, it'll be this:
add interface=ether3 address=192.168.2.1/24 disabled=no
add interface=ether4 address=192.168.3.1/24 disabled=no
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
anav
Thu Nov 05, 2020 7:19 pm
I would post your config to ensure firewall rules etc dont get in the way or are providing adequate coverage.
Besides address above you will need to complete the dhcp settings, pool etc....... (SO three DHCP serving networks on the router).
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Users browsing this forum: No registered users and 18 guests
