richammond
BGP Manual Refresh
Thu Dec 03, 2020 12:30 pm
Dear SysAdmins,
We're looking to hard refresh our BGP session. The command '/routing bgp peer refresh' is a soft reconfigure which isn't what we're after. We need the hard BGP refresh. On a cisco router, the command is clear ip bgp IP out
Would anyone know what the equivalent on a mikrotik is? We're using the CCR1072 with RouterOS 6.47.8
Thanks in advance
Kind Regards
mrz
Re: BGP Manual Refresh
Thu Dec 03, 2020 12:34 pm
What do you mean by hard refresh. Tear down the session and restart? If so then peer disable/enable.
richammond
Thu Dec 03, 2020 12:46 pm
Hi mrz,
Thanks for the response. Disabled/Enabled the peer, and then rebooted the box and also switched off the CCR completely for 10 mns and powering it back on, but no effect - The routes are still not being advertised :-( and yes, they're added/filtered exactly the same way as all the previous ones.
Kind Regards
Users browsing this forum: No registered users and 10 guests
