AhmedFakkar
VLAN over VPLS Link
Mon Dec 07, 2020 4:28 pm
I have manged to implement VPLS link between two different Mikrotik routers. Now, i need to be able to pass VLAN tagged traffic in addition to native VLAN traffic. I have tried multiple configuration but it didn't work. Could any one recommend the correct steps and configuration for achieving this?
Thanks in advance.
Ahmed
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Re: VLAN over VPLS Link
Wed Dec 09, 2020 12:40 am
You will add vlans the same way as you would with other interfaces.
Post your attempt with vlan config here and we can see where you going wrong and can try and assist you
MTCNA, MTCTCE, MTCRE & MTCINE
mducharme
Trainer
Trainer
Wed Dec 09, 2020 1:13 am
The default layer 2 MTU of a VPLS tunnel is 1500 which is too small to admit a VLAN tag with a full size packet. You'll need to increase your advertised L2MTU to at least 1504 from 1500.
AhmedFakkar
Wed Dec 09, 2020 2:36 am
I have already done this and here is the VPLS interface,
0 DB name="vpls21" mtu=1500 l2mtu=1550 mac-address=02:2B:05:71:1C:78 arp=enabled
arp-timeout=auto disable-running-check=no remote-peer=10.20.1.2 cisco-style=no
cisco-style-id=0 advertised-l2mtu=1550 pw-type=raw-ethernet
use-control-word=yes vpls=MGMT-VPLS
AhmedFakkar
Wed Dec 09, 2020 2:41 am
Connection should be as the following, Server > Mikrotik CCR1036 > VPLS > Mikrotik CCR2004 > Server.
I am trying to make both server communicate through VLAN "2". I have added the VLAN and allowed it through the port towards the server and through VPLS link.
I have bridged both VPLS and Server's port as well.
# NAME MTU ARP VLAN-ID INTERFACE
1 R Server-2 1500 enabled 2 ether4
2 VPLS 1500 enabled 2 vpls21
3 Bridge-VLAN 1500 enabled 2 MGMT
CZFan
Wed Dec 09, 2020 9:54 am
You are using BGP signaled VPLS, these VPLS interfaces are created dynamically which makes assigning Vlans difficult as the VPLS interface will change as and when router reboots, etc.
I don't know if there is a solution to this, have not worked much with BGP signaled VPLS
AhmedFakkar
Wed Dec 09, 2020 2:32 pm
[/quote]
[/quote]
Thank you for your feedback.
Can i know how to setup it at least? I will deal with VPLS tunnel changing after rebooting
CZFan
Wed Dec 09, 2020 3:10 pm
Mikrotik Wiki Article on Bridge Vlan:
https://wiki.mikrotik.com/wiki/Manual:Bridge_VLAN_Table
Herewith a good tutorial from a forum member:
viewtopic.php?f=13&t=143620&p=833307&hi ... an#p706996
IPANetEngineer
Trainer
Trainer
Wed Dec 09, 2020 3:52 pm
If you want to pass all VLANs like a trunk over VPLS without specifying each VLAN, here is a blog article I wrote with config examples on how to use S-Tag for this.
https://stubarea51.net/2018/08/07/mikro ... and-s-tag/
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
AhmedFakkar
Wed Dec 09, 2020 11:03 pm
Thank you
Users browsing this forum: No registered users and 14 guests
