mhugo
Local preference not applied in BGP
Fri Dec 18, 2020 7:49 pm
Im trying to apply local preference to incoming bgp from external peer. Its the only filter router I have for the peers inbound bgp.
Neither of these work and its announced to the internal BGP routers in same AS.
add action=accept append-bgp-communities="" chain=bgp-transit4-in set-bgp-communities="" set-bgp-local-pref=75
add action=accept append-bgp-communities="" chain=bgp-transit4-in prefix=0.0.0.0/0 set-bgp-communities="" set-bgp-local-pref=75
This should be simple so Im probably just stupider than usual. :)
/Mikael
guntis84
Re: Local preference not applied in BGP  [SOLVED]
Wed Dec 30, 2020 1:30 pm
Filtrs pareizs, tikai jāpievieno BGP peeram! ;)
mhugo
Wed Dec 30, 2020 1:34 pm
Yes this was for sure an operator bug :) For other users with the same issue - make sure the filter is applied to the bgp peer.
Users browsing this forum: No registered users and 9 guests
