sewlist
Using traceroute in MPLS networks
Wed Jun 17, 2009 12:45 pm
Hi guys,
im trying to understand the Penultimate hop popping errror produced by traceroute
on my network when i traceroute to my peer where we co-locate i get the timeout which is right according to documentation , but is there anyway to avoid this and still see the lables?
ADDRESS STATUS
1 x.100.0.1 2ms 1ms 1ms
2 x.168.253.1 4ms 3ms 3ms
mpls-label=3873
3 0.0.0.0 timeout timeout timeout
4 x.168.249.254 3ms 3ms 2ms
5 x.10.45.254 6ms 5ms 2ms
6 x.221.1.208 3ms 5ms 2ms
How come when i traceroute for example to google, they also show mpls lables but there is no Penultimate hop popping happening timeouts from the ISPs? is this a way they configure their mpls domain ips?
example
2 196.44.0.172 246ms 246ms 246ms
mpls-label=270992 exp=1
3 196.44.31.203 248ms 253ms 248ms
mpls-label=112786 exp=1
4 209.212.127.129 268ms 314ms 318ms
5 198.32.160.130 246ms 246ms 246ms
6 209.85.255.68 247ms 292ms 246ms
7 209.85.251.9 267ms 268ms 268ms
8 72.14.232.213 268ms 269ms 268ms
9 209.85.253.145 270ms 270ms 270ms
10 74.125.45.99 268ms 269ms 268ms
S
Mplsguy
Re: Using traceroute in MPLS networks
Wed Jun 17, 2009 5:28 pm
http://wiki.mikrotik.com/wiki/MPLSVPLS# ... ce_address is talking about missing traceroute reply from first hop. The reason discussed there should not cause any further hop replies to be lost (assuming that everything is set up properly and operational). So this must be something else. Please provide more information on your network setup.
sewlist
Wed Jun 17, 2009 6:53 pm
okay let me try be more clear about network setup
i've enabled mpls ldp on the all the primary routers
ill use below tracroute as how mpls is enabled for that route, hope its ok?
tool traceroute x.221.1.208 src-address=10.10.11.105
ADDRESS STATUS
1 172.101.1.1 2ms 1ms 1ms
2 10.168.253.5 3ms 2ms 2ms
mpls-label=3115
3 10.168.253.1 5ms 2ms 2ms
mpls-label=3873
4 0.0.0.0 timeout timeout timeout
5 192.168.249.254 3ms 2ms 2ms
6 10.10.45.254 3ms 3ms 2ms
7 x.221.1.208 3ms 2ms 3ms
hop 1 mpls ldp enabled on loopback 10.255.255.3/32
hop 2 mpls ldp on loopback 10.255.255.2/32
hop 3 mpls ldp on loopback 10.255.255.1/32
hop 4 mpls ldp on loopback 10.255.255.23/32
hop 5 and 6 mpls was enabled but I need to masquerade to a certain ip at co-location so had to disable it
hop 7 is server
I can traceroute perfect between routers using the correct 10.255.255.x source ip address, and my above traceroutes works fine, however its looks "ugly" in the trace for clients who does checks on their stations
does this makes sense above? I presume hop 4 is the egress LER ?
S
Mplsguy
Wed Jun 17, 2009 10:04 pm
On which hop do you masquerade? And how is propagate-ttl configured on your LSRs?
sewlist
Thu Jun 18, 2009 10:45 am
on hop 5 and 6 which is the same router I masquerade to just one ip which we can't route to
If i enable mpls ldp on hop 5 and 6 , i get the timeout in the traceroute just after that
mpls propagate-ttl: yes on all the routers
S
Users browsing this forum: No registered users and 7 guests
