ZamNam
Bridging Question
Wed Sep 16, 2009 5:38 am
Hi, i am using routeros v: 2.9 on an x86 Pc have two Ethernet cards installed, one is connected to a (main router) with a different subnet range than the local, i would like to know if i can bridge a single client in the local subnet to be able to connect directly to the main router .
so simply it would be in the local physical subnet but it is connected to the main router subnet ..
thank you
Chupaka
Re: Bridging Question
Wed Sep 16, 2009 4:06 pm
if there are different subnets - then you need routing, not bridging
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
ZamNam
Wed Sep 16, 2009 4:53 pm
i mean i need this single machine to communicate directly to the main subnet as if it was out there not local
i dont wanna give this machine a local ip address
how can i get to do that
thank you
Chupaka
Wed Sep 16, 2009 5:49 pm
hmmm... maybe you can create bridge, add both subnets to that bridge - and then block any bridge forwarding except that client... but it's perversion =)
Users browsing this forum: No registered users and 15 guests
